Fibre installed today. Need assistance to upgrade to full speed.
donka
Hi All,
Just had my fibre connection installed this morning and the engineer has confirmed it is syncing at the full 80/20 speed as I had expected. The checker only estimated 12.5mbps and so the sales team would not let me order Fibre Extra. Now it syncing at full speed, can someone assist me in getting the extra product enabled please?
Thanks,  Andy.
MattyC
Champion
Fixes: 46
Re: Fibre installed today. Need assistance to upgrade to full speed.
Hi Andy,
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Looking good so I've switched the packages around. You ok to log into your router and disconnect/connect?
Matty
donka
Thanks Matty.
I have disconnected and now rebooted the HomeHub. Should that be all that is required?
Also, can you confirm I will be on the discounted rate? I have a message from the sales team of what the Fibre Extra rate would be if I got upgraded.
Cheers,  Andy.
MattyC
Champion
Fixes: 46
I left the levels of discount the same, so it should be about £5 more expensive. And yes, that should be fine.
donka
Thanks Matty again for your help. A quick question though. I still appear to be on 40 down. Does it take some time to kick in?
I also checked the link below and this morning it reported 40mb line speed with my phone number but now it is showing 80mb line speed but with a totally different phone number and exchange!
Any ideas?
Fixes: 62
I was told that a product change takes up to 24 hours at BT end
MattyC
Champion
Fixes: 46
Ahhhh that's my mistake. I'm still living in a world where everything was provisioned 80/20, so I forgot that an order would need placing. Jim is correct, it should take 24 hours for everything to be maximised.
My apologies donka.
MattyC
Champion
Fixes: 46
Sorry for the double post. Are you ok to check up on the exchange again?
donka
Thanks both. I'll look out for the speed increase tomorrow.
I've checked the exchange again and it is correctly showing my speed as 80mb with the correct telephone number and exchange.
Thanks again, I really appreciated the support.
Andy.
MattyC
Champion
Fixes: 46
No worries Andy, all the best for tomorrow.
donka
Apologies for not replying as it slipped my mind. Got the speed increase and all is looking good.
Thanks for the assistance.
MattyC
Champion
Fixes: 46
Ah, cheers for getting back to me Smiley
