Fibre installed - profile needs updating
puffin
As the title says, my fibre is still behaving like an ADSL2 line.  Can somebody nudge the profile please?
Seatonsurfer
Re: Fibre installed - profile needs updating
Reboot the router and see if it makes a difference.
Fixes: 32
Hi @puffin,
We just needed to update the account details and change the package for you.
I've done that so please try rebooting if you're not seeing any difference to speeds.
 Adam Walker
puffin
Thanks, Adam.
Unfortunately, despite rebooting both the modem and the router I'm still stuck with ADSL-like performance: http://www.speedtest.net/my-result/4898194285
Fixes: 136
Is it still the same now?
 Matthew Wheeler
puffin
It was at 7:30 this morning.  I'm not at home now to check.
Are you able to confirm the speed my modem is syncing at just so I know what I should be getting?
puffin
Still no increase in speeds.  Upload is clearly stuck at ADSL2 levels Sad
http://www.speedtest.net/my-result/4901236414
As I'm using a BTO modem it would be good if you could let me know my line stats for comparison.
MelRocks
Just to check are these speeds tests on a wired or wireless connection? Thanks.
puffin
I'm getting the same speeds whether I test on wired gigabit or wireless N.
puffin
So after a 70 minute wait (really, PN, really?  I remember the days of getting straight through to Customer Service and that was only 5 years ago) on the phone to speak to someone we've discovered that my modem is happily syncing at 50/20 so why I can only get throughput of 20/0.2 is a mystery.  Off to the faults team to sit on it for 72 hours try and get it fixed asap!  Wink
puffin
Update: I'm a numpty!
Now seeing this: http://www.speedtest.net/my-result/4904396300
Turns out that my router has a QoS setting that had been enabled back when we were on ADSL2 and it was rate limiting the upload to 256kbps.   Roll eyes
