Fibre installed - Speed profile nudge
sp1ke
Dear PN,
Just had fibre installed, provisioned on the 80 / 20 package.
Please could my speed profile be adjusted accordingly?
Engineer was prompt and efficient  Smiley
Thank you
26 REPLIES 26
HarryB
Fixes: 256
Re: Fibre installed - Speed profile nudge
Hi sp1ke,
Looks like the order hasn't closed off yet so this is probably why the profile hadn't bumped up yet.
I've manually changed this for you so hopefully you should see the increased speeds now.
 Harry Beesley
sp1ke
Thank you Harry that's done the trick.
Would just like to say the whole migration process from ADSL to VDSL was faultless.
Thank you.
deejayburnout
Sorry for posting on your thread sp1ke,
i too have just had fibre installed but my speeds are still below 80/20. currently at 26/1.8. I contacted plusnet earlier to have my profile line speed changed from 7.1 to 78 but speed jump as not fully reflected that.
MatthewWheeler
Fixes: 479
@deejayburnout
Unfortunately the agent who placed the order chose the wrong speeds. I've placed a order to sort this which will complete Monday.
 Matthew Wheeler
deejayburnout
thanks for sorting that. I was expecting it to start at 80/20 then over the next 10 days, adjust itself accordingly.
Shall i need to turn off my router and fiber box when i get home?
MatthewWheeler
Fixes: 479
Nope it's all automatic in theory so you shouldn't have to do anything.
 Matthew Wheeler
deejayburnout
Thanks for that. Just got home and speeds are slightly higher on download but upload is still less than 2mb
MatthewWheeler
Fixes: 479
It won't be sorted till Monday I'm afraid but you'll notice a huge improvement then.
 Matthew Wheeler
deejayburnout
Just checked and now working fine
MatthewWheeler
Fixes: 479
That's a lot better.
Glad to see it's fully working now.
 Matthew Wheeler
deejayburnout
Bit of an update.
Was fast, now this.
Really???
MatthewWheeler
Fixes: 479
The profiles still correct so not sure why that's happened.
Was that over wired or wireless?
 Matthew Wheeler
deejayburnout
This was a wired connection.
Seems to be fine in the morning but as the day goes on it gets worse. Been the same for a few days
deejayburnout
just got home and done a speedtest
done again on the same server as previous tests
This is a bit of a joke.
