Fibre installation
- Re: Fibre installation
Fibre installation
25-09-2017 5:33 PM
26-09-2017 2:48 PM
Hello there,
I'm sorry if you've not heard much from us in terms of updates. I've chased this up and can see that Openreach are waiting for line plant to be arranged, that basically means any equipment they need before the work can go ahead.
We've been advised to expect an update by the end of the day on Thursday so I'll follow this up with you then.
28-09-2017 5:15 PM
I've spoken with Openreach again and the lineplant work has been signed off and is being put in place so that the necessary cabling work to get you connected can take place. I've been advised that should take up to a further 48 hours so I'll check back in with you next week to see where we stand.
