Fibre goes slow, dsl Flashes then Internet Fails Altogether
- Fibre goes slow, dsl Flashes then Internet Fails A...
28-11-2015 2:55 PM
I've a FTC fibre network that has been great up to about 3 weeks ago.
Suddenly the speed dropped from ~23M to about 8.7M, then internet disappeared altogether. The phone was VERY crackly and noisy!
I found the internet had dropped, and on investigation found the Internet light on the PlusNet router wasn't on, and the DSL light on the BT router was flashing. After a while the BT DSL became steady, but still no Internet. Powered the PlusNet router down, then up and after the usual wait all was back to normal (and ~23M)
This situation has been repeated a few times since but WITHOUT the phone line apparently playing up, each time the speed drops to about 8 - 9 M, then the BT router DSL light blinks and/or goes off. After a while the BT DSL light comes back on but there's no connection to the internet UNTIL the PlusNet is powered down & back up (is there a way of kick starting the internet connection via the plusnet router interface?)
It's becoming difficult to rely on the connection, can anyone suggest what checks I can do or what can be done at the PlusNet end
update; 28/Nov/2015@19:20; 3 dropouts in last 20 minutes, phone line is crackling again
[Moderator's note by Dick(Strat) All capstext in title edited as per forum rule
Message 1 of 3
(946 Views)
2 REPLIES 2
Re: Fibre goes slow, dsl Flashes then Internet Fails Altogether
29-11-2015 3:05 AM
You should report a PSTN voice telephony fault to who ever you pay line rental to, as if you can here audible noise it usually can be evidence of a HR type fault, but to exclude the filter remove the face plate on the master socket and plug a corded phone if possible into the test jack and do the quiet line test again, if you can still hear noises then report a fault
Message 2 of 3
(440 Views)
30-11-2015 9:35 AM
Message 3 of 3
(440 Views)
