Fibre fitted today. Quick question.
- Fibre fitted today. Quick question.
29-01-2015 6:52 PM
Moved from adsl to fibre today. The chap on the phone said the speed would bounce around for 7-10days.
Mr BT tested the line with his PDA type device. It came back with a really high capacity 60mb+
The upload speed is through the roof but the download speed hasn't changed at all!
Is this normal?
Re: Fibre fitted today. Quick question.
29-01-2015 6:57 PM
Your profile hadn't updated on our end.
I've just done that now and if you log into the router and disconnect then reconnect you should see a increase.
Alternatively you can just reboot our router which has the same effect.
29-01-2015 7:16 PM
29-01-2015 7:19 PM
29-01-2015 7:20 PM
29-01-2015 7:22 PM
29-01-2015 7:29 PM
29-01-2015 7:29 PM
29-01-2015 7:31 PM
29-01-2015 7:38 PM
29-01-2015 7:45 PM
29-01-2015 7:47 PM
29-01-2015 8:17 PM
29-01-2015 8:27 PM
29-01-2015 8:48 PM
up 15.73
ping 26.63
