Fibre extra no quicker.
- Re: Fibre extra no quicker.
14-11-2017 7:40 PM
Thanks. On the test socket for the time being. Slight speed increase +1meg.
What router stats are you needing? I'm using the openreach modem and Asus 66 router.
Thank you
14-11-2017 7:47 PM
Hello.
I upgraded to Fibre Extra at the weekend and it was activated on 13 Nov. My speed has changed from an average 38mb in the past year or so to 37mb today!
Does it take a few days for the system to put the increased speed on perhaps or am I not getting something I have paid for?
14-11-2017 8:05 PM
The more the better.
14-11-2017 8:20 PM
I may sound thick saying this but I don't know what stats you require. Sorry.
14-11-2017 8:41 PM
14-11-2017 8:43 PM
I think the data rate would be useful, though I wouldn't know how you'd get it from your router.
I'll be happy to retest your line tomorrow with your router plugged into the test socket.
14-11-2017 8:45 PM
No DSL log I can see.
14-11-2017 9:27 PM
14-11-2017 9:29 PM
The connections log is local connections to the router.
14-11-2017 9:35 PM
The OP has an Openreach modem, so won't be able to see DSL stats unless its unlocked.
14-11-2017 9:50 PM
14-11-2017 9:55 PM
I like the Asus router but would a different modem be better than the openreach modem I have?
15-11-2017 8:55 AM
If your line is banded at 44Mbps changing the modem will have no effect, the banding needs to be removed but that is not easy. BT Openreach DLM is very reluctant to automatically remove it. An engineer can reset DLM after a fault has been fixed so you need to get PlusNet to arrange an engineer appointment as your speed is so far below your estimates. You should be getting around 70Mbps or more.
15-11-2017 11:03 AM
My area looks to have been recently upgraded and my banding is also stuck so my current line speed is around 17mbit and upload of 2mbit. The order to move to fibre plus completed in the early hours of this morning but the profile is still stuck.
Did you get this sorted in the end? @Gandalf is hopefully taking a look at my issue today and I can see he's been active in this thread.
15-11-2017 5:11 PM
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 42.1 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 495.4 |
Upstream Rate Assessment | Low |
Downstream Rate Assessment | Low |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
Profile Name | 0.128M-44M Downstream, Retransmission High - 0.128M-20M Upstream, Retransmission Low |
Time Stamp | 2017-11-10T17:00:00 |
I can see we're looking into booking another engineer visit to further investigate this.
Can you let us know if it goes ahead and how you get on?
