Fibre extra dropped to 20Mbps
FIXED- Subscribe to RSS Feed
- Fibre extra dropped to 20Mbps
29-10-2019 2:56 PM
I've detected that my fibre extra download speed has dropped drastically, to about a third of guaranteed minimum. Upload doesn't appear to be impacted.
From the product change email:
At peak times, we estimate that you'll get the following speeds on your line:
Download: 59 - 72Mb
Upload: 17 - 18Mb
Minimum Guaranteed Speed: 53.6Mb
I've carried out all the usual tests:
17070 QLT shows no noise on the line
the BT Wholesale speed test is returning around 18 - 20 Mbps down. Tested with a a wired connection, nothing else plugged in, wireless disabled, and into the test socket.
Looking through the router logs the only thing I can see of note is a series of PPPoE down/up overnight on the 4th and 6th October, not sure if that is enough to impact.
see enclosed screenshots
Help!
Fixed! Go to the fix.
Re: Fibre extra dropped to 20Mbps
29-10-2019 4:45 PM
Have you checked that your phone is working? One of the twe cores in the cable to your home can cause this. If so report a phone not broadband fault. Alternatively do a quiet line test by ringing 17070 then option 2. Again if noisy report a phone fault.
29-10-2019 4:57 PM
Sorry to hear you've recently been experiencing issues with your upload speed.
I've had a look over the account and spotted something that was incorrect. If you disconnect and reconnect, your speeds should be back to normal.
Apologies for any inconvenience this caused.
29-10-2019 4:58 PM
Thanks Baldrick, I have already carried out the 17070 option 2 test hearing no noise or crackle.
calls in and out are also working ok.
29-10-2019 5:05 PM
Harry, whatever you did fixed it. Back to my normal ~58 download.
Many thanks for your swift fix.
Ken
30-10-2019 10:08 AM
