Fibre extra 40mbps
jt
Fibre extra 40mbps
Seriously? Why am I paying extra if I am not getting the correct speed?
I have complained about this problem numerous times and not had it sorted at all.
1 REPLY 1
Fixes: 167
Re: Fibre extra 40mbps
From the last fault you raised I can see you were in sync at 74Mb/s and getting not far off that when doing speed tests, if things are worse and the speed has dropped you'd need to go through the faults process for investigation.
 Chris Parr
 Plusnet Staff
