Fibre , evening and morning speeds only 1-2 meg down
lxkid
Hi, I wonder if a staff member or some helpful person can look at my account graph, these past few weeks my broadband speed have dropped to as low as 1 meg, last night I was unable to stream the football on my iPad which really frustrated me.
Any help would be appriciated.
Any questions I will try my best to answer .
Fixes: 236
Re: Fibre , evening and morning speeds only 1-2 meg down
Our tests aren't showing any obvious issues I'm afraid.
Is it possible for you to test a wired connection to see if that performs any better?
 Matthew Wheeler
lxkid
I shall do another one for you, also I opened up the router to have look and I was getting a lot of firewall icmp check which failed to reach its destination? I know around this time I was trying to stream bt sports on iPad but it just kept streaming for a few seconds then buffering for ages... Unwatchable .
Fixes: 236
Don't worry about the router logs that wouldn't cause this issue.
You might want to try going through the guide here if the ethernet connection works fine.
If you want to change the wireless channel there's a video below for your router that'll help.
 Matthew Wheeler
lxkid
Thank you, I'm just setting up the laptop then I will go from there.
lxkid
It's seems to be when wired, 3 tests done all above 70 down and 19 up.
I will try the channel change.
Fixes: 236
That definitely points towards the wireless being the issue.
Let us know how you get on.
 Matthew Wheeler
lxkid
I manually changed the station, I started with 1 and it seems to working like it used to.
I will keep an eye on it , and report back.
Thank you very much for your help and info.
Regards al
Fixes: 236
Fantastic glad to hear it!
 Matthew Wheeler
