Fibre , evening and morning speeds only 1-2 meg down
FIXED- Subscribe to RSS Feed
- Re: Fibre , evening and morning speeds only 1-2 me...
07-04-2016 12:05 PM
Hi, I wonder if a staff member or some helpful person can look at my account graph, these past few weeks my broadband speed have dropped to as low as 1 meg, last night I was unable to stream the football on my iPad which really frustrated me.
Any help would be appriciated.
Any questions I will try my best to answer .
Fixed! Go to the fix.
Re: Fibre , evening and morning speeds only 1-2 meg down
07-04-2016 12:16 PM
07-04-2016 12:21 PM
I shall do another one for you, also I opened up the router to have look and I was getting a lot of firewall icmp check which failed to reach its destination? I know around this time I was trying to stream bt sports on iPad but it just kept streaming for a few seconds then buffering for ages... Unwatchable .
07-04-2016 12:26 PM
Don't worry about the router logs that wouldn't cause this issue.
You might want to try going through the guide here if the ethernet connection works fine.
If you want to change the wireless channel there's a video below for your router that'll help.
07-04-2016 12:28 PM
Thank you, I'm just setting up the laptop then I will go from there.
07-04-2016 12:42 PM
I will try the channel change.
07-04-2016 12:45 PM
07-04-2016 12:56 PM
I will keep an eye on it , and report back.
Thank you very much for your help and info.
Regards al
07-04-2016 12:57 PM
