Fibre disconnections
- Fibre disconnections
24-07-2016 9:41 PM
I got disconnected twice tonight.
The log shows:
21:09:35, 24 Jul. | (984771.710000) CWMP: session closed due to error: No response |
21:09:35, 24 Jul. | (984771.690000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:09:35, 24 Jul. | (984771.690000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
21:09:35, 24 Jul. | (984771.440000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
21:09:34, 24 Jul. | (984770.540000) PPPoE is down after 16410 minutes uptime [Disconnected] |
21:09:31, 24 Jul. | (984768.050000) PPP LCP Send Termination Request [PPPoE PADT received] |
and then again:
21:10:28, 24 Jul. | (984824.220000) CWMP: session completed successfully |
21:10:27, 24 Jul. | (984824.040000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
21:10:21, 24 Jul. | (984817.790000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:10:21, 24 Jul. | (984817.780000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
21:10:19, 24 Jul. | (984815.680000) WAN operating mode is VDSL |
21:10:19, 24 Jul. | (984815.680000) Last WAN operating mode was VDSL |
21:10:17, 24 Jul. | (984814.000000) PPP IPCP Send Configuration ACK |
21:10:17, 24 Jul. | (984814.000000) PPP IPCP Receive Configuration Request |
21:10:17, 24 Jul. | (984813.750000) PPP IPCP Receive Configuration ACK |
21:10:17, 24 Jul. | (984813.750000) PPP IPCP Send Configuration Request |
21:10:17, 24 Jul. | (984813.740000) PPP IPCP Receive Configuration NAK |
21:10:17, 24 Jul. | (984813.730000) PPP IPCP Send Configuration Request |
21:10:16, 24 Jul. | (984812.230000) PPPoE is up - Down Rate=79995Kbps, Up Rate=19999Kbps; SNR Margin Down=10.7dB, Up=23.2dB |
21:10:16, 24 Jul. | (984812.220000) CHAP authentication successful |
21:10:16, 24 Jul. | (984812.100000) CHAP Receive Challenge |
21:10:16, 24 Jul. | (984812.100000) Starting CHAP authentication with peer |
21:10:16, 24 Jul. | (984812.090000) PPP LCP Receive Configuration ACK |
21:10:16, 24 Jul. | (984812.080000) PPP LCP Send Configuration ACK |
21:10:16, 24 Jul. | (984812.080000) PPP LCP Send Configuration Request |
21:10:16, 24 Jul. | (984812.080000) PPP LCP Receive Configuration Request |
21:10:15, 24 Jul. | (984811.770000) CHAP Receive Challenge |
21:10:15, 24 Jul. | (984811.770000) Starting CHAP authentication with peer |
21:10:15, 24 Jul. | (984811.760000) PPP LCP Receive Configuration ACK |
21:10:15, 24 Jul. | (984811.760000) PPP LCP Send Configuration Request |
21:10:15, 24 Jul. | (984811.760000) PPP LCP Receive Configuration Reject |
21:10:15, 24 Jul. | (984811.760000) PPP LCP Send Configuration ACK |
21:10:15, 24 Jul. | (984811.760000) PPP LCP Receive Configuration Request |
21:10:05, 24 Jul. | (984801.980000) CWMP: session closed due to error: No response |
21:10:05, 24 Jul. | (984801.960000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
21:10:05, 24 Jul. | (984801.950000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
Any ideas? Thanks.
Message 1 of 4
(646 Views)
3 REPLIES 3
Re: Fibre disconnections
25-07-2016 10:56 AM
Testing the line isn't showing any obvious issues, can you get this reported at https://faults.plus.net if you continue to have issues.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0001 |
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 80.0 Mbps |
Upstream Speed | 20.0 Mbps |
25-07-2016 11:00 AM
Thanks Chris, will do.
Message 3 of 4
(620 Views)
25-07-2016 11:03 AM
We can see the 2 disconnections as per the graph (right next to each other) but it looks pretty stable other than that.
