Fibre connection worse than copper
pir8ped
After my ten days of settling in, my fibre connection remains awful. I have seen a maximum speed of 26 (I think I was guaranteed 35) and I have used speedtest a lot, often to see if there is any connection at all. The attached file showing a speed of less than 1 Mb/s isn't unusual. Commonly, speeds are around 11, which is what I was getting with the copper connection, but the copper connection was more stable. Quite often, the fibre connection cuts out altogether, and the light on the router turns red (and yes, the router is connected to the master phone socket).
My next door neighbour, also with Plusnet FTTC has the same performance, and says he has just given up complaining as he got nowhere (the copper wire between his house and the pole was replaced, but that didn't help). I have 2 neighbours up the road who switched to fibre at the same time as me, with EE, and they both get a steady 35 Mb/s. They are further from the cabinet.
So clearly, Plusnet needs to fix this, or two customers are heading over to EE.
6 REPLIES 6
Mav
Fixes: 514
Re: Fibre connection worse than copper
Moderator's note(s):
Thread moved from ADSL Broadband to Fibre Broadband.
Forum Moderator and Customer
pir8ped
Thanks for moving this to the right section.
Any idea when someone from Plusnet might address the problem?
adamwalker
Fixes: 221
Hi there, I've just taken a look into this for you and whereas diagnostic tests show that downstream speeds are currently below estimates, no obvious causes are being flagged up. Please report a fault with us over at http://faults.plus.net as your next step and we'll be able to investigate this further for you.
 Adam Walker
pir8ped
Thanks. Will do.
pint
Plusnet don't offer fibre, only copper based connections
pop your details into the openreach DSL checker ste here to see your expected speeds: https://www.broadbandchecker.btwholesale.com/#/ADSL
 you should be looking at VDSL ( comes down copper wires)
if you see WBC FTTP then you are in a fibre area, and you may be able to move to an alternative provider that offers fibre connections
Wait to see if plusnet can improve your VDSL connection, and if not and you are in a fibre area and are happy to pay the price for fttp then you may be able to move to EE or BT ( for fibre ) from plusnet without any early termination fees - although this will need checking before you jump
pir8ped
Thanks for that. Useful site link.
I thought the term fibre included fibre to the cabinet. I appreciate it's copper the rest of the way. I know what I've got, but I got the terminology wrong.
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date WBC SOGEA Availability Date Left in Jumper
High Low High Low
VDSL Range A (Clean)  52.6 35 8.8 6.6 32.4 Available Available --
VDSL Range B (Impacted)  50.6 32.4 8.6 6 27.4 Available Available --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 330 30 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in Jumper
WBC ADSL 2+ Up to 9.5 -- 8 to 11 Available Available Yes
WBC ADSL2+ Annex M Up to 9.5 Up to 1 8 to 11 Available Available Yes
ADSL Max Up to 8 -- 7 to 8 Available Available --
WBC Fixed Rate 2 -- -- Available Available Yes
Fixed Rate 2 -- -- Available -- --
Observed Speeds VDSL ADSL
Max Observed Downstream Speed 26.57 15.56
Max Observed Upstream Speed 6.33 0.88
Observed Date 2021-03-12 2021-03-09
Other Offerings Availability Date
VDSL Multicast Available
ADSL Multicast Available
Premise Environment Status
Bridge Tap U
VRI N
NTE FacePlate N
Last Test Date 10-03-2021
Exchange Product Restrictions Status
FTTP Priority Exchange N
WLR Withdrawal N
SOADSL Restriction Y
