Fibre connection up and down often in the last few days
Lostinza
For the last few days we've had the link go up and down a lot. Nothing changed my side configuration wise. Anybody know of any outages, etc?
Thanks,
Kerryn
5 REPLIES 5
OskarPapa
Fixes: 64
Re: Fibre connection up and down often in the last few days
Hi @Lostinza, thanks for your post.
We're sincerely sorry to hear of this issue.
On checking the line, we're detecting a couple of issues as shown in the below GEA test:
GEA Test Detail
Circuit ID <REDACTED> Service ID <REDACTED>
Test Outcome Fail
Test Outcome Code GTC_FTTC_SERVICE_1624
Description Impairment in copper joint detected most likely close to customer premises. Please continue to submit a trouble report.
Main Fault Location CA
Sync Status In Sync
Downstream Speed 36.7 Mbps
Upstream Speed 16.4 Mbps
Appointment Required Y
Fault Report Advised Y
NTE Power Status PowerOn
Voice Line Test Result Not Run - Unable to run
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 296.1
Upstream Rate Assessment Low
Downstream Rate Assessment Low
Technology VDSL
Profile Name 0.128M-67M Downstream, Interleaving Low - 0.128M-20M Upstream, Interleaving On
Time Stamp 2019-06-20T11:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 36.6 Mbps 58.9 Mbps 55.6 Mbps
Up Stream Line Rate 11.9 Mbps 19.2 Mbps 18.5 Mbps
Up Time 732.0 Sec 900.0 Sec 897.1 Sec
Retrains 0.0 9.0 0.1
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-07-03T10:13:09Z 2019-07-03T10:28:09Z
Ingress Code Violation 58 62
Egress Code Violation 37 35
Errored Seconds 7 7
Severely Errored Seconds 2 3
Unavailable Seconds 0 26
Due to the above, I've just raised a fault with our suppliers and we're being told that we're going to need to arrange for an engineer to visit and hopefully resolve the issues.
I've just sent you a ticket, accessible here, which I do need a response to in order to proceed.
As soon as you've responded please let me know here and I'll book in that engineer ASAP.
Lostinza
Thanks for the prompt response @OskarPapa.
I've updated the ticket.
adamwalker
Fixes: 175
Hi there, I've just sent a reply back to the ticket for you. I hope that helps to move things forward for you.
 Adam Walker
Lostinza
Thanks @adamwalker . I have replied.
TheMightyAJ
Fixes: 116
Hi @Lostinza,
Thank you for getting back in touch with us. I've updated the ticket further following your latest reply. Please let us know if you have any further queries regarding the update or if you respond to the ticket so that we can pick this up for further review.
 Alex H
