Fibre connection issues in Kent
- Fibre connection issues in Kent
30-05-2021 11:45 AM
Started having issues with Fibre connection since yesterday, every hour it will go down at least for a minute (flashing orange light) then comes back on again, still happening today at least once every hour.
Is there any current known issues in Kent area that could be causing this?
Re: Fibre connection issues in Kent
30-05-2021 12:08 PM
@Jimash Welcome to the forums. If there were major problems, there would be a lot more than just you asking. Try putting your phone number in here: https://status.zen.co.uk/broadband/ to check for local problems. If none reported - have a look at the 'Fibre - speed faults' topic towards the top of this board.
30-05-2021 12:14 PM
31-05-2021 10:53 AM
Hi @Jimash,
I'm sorry to hear that you're experiencing this issue. Having tested your line this morning, we're able to see there's an underlying fault, though I'm afraid that we're unable to see what
the cause of the fault is. If you haven't already had the chance then I'd recommend running through the following troubleshooting guides:
Broadband Troubleshooting Guide
If you continue to experience issues with your connection then please let us know and we'll be happy to investigate the matter further.
31-05-2021 10:59 AM
I have had no issues since yesterday afternoon and all fine today
If it happens again I'll follow the steps you sent. Thank you for your help!
