Fibre connection dropping regularly: help would be much appreciated.
- Fibre connection dropping regularly: help would be...
- « Previous
- 1
- 2
- Next »
Re: What on earth could be causing this?
27-02-2019 8:13 PM
Moderators Note
Two topics on the same subject merged to keep all information in one place and assist staff in helping.
Message 16 of 17
(196 Views)
28-02-2019 9:22 AM
Hi @rgouther
Thanks for the update.
I can see that we've arranged for a replacement router to be sent to you in order to combat the above - has this arrived yet?
If you're currently using the newer router, I'd suggest raising a fault here so that we can ask our suppliers to take a look at this for you - alternatively, if the router hasn't arrived yet, give it a go when it does (it's on its way already) and let us know how you get on.
Best wishes
Dave
Message 17 of 17
(174 Views)
- « Previous
- 1
- 2
- Next »
