Fibre connection down already
Studio_Two
I've only been on FTTC for a few months, but already it has failed. The DSL light is out on the modem. I'm waiting  for an engineer appointment to be arranged.
Is it worth borrowing a modem from elsewhere and testing that out? Are these modems reliable? I can't see what else could be wrong that might require the engineer to visit my home.
Any advice is much welcome.
Regards,
Stephen
18 REPLIES 18
godsell4
Re: Fibre connection down already
Ask you neighbours if they or anybody else near you is also having problems either right now of very recently?
Open up the filtered faceplate and connect your modem to the master socket to rule out the problem being due to the internal phone wiring in your house.
Yes it is worth trying a different modem, it is not likely to be the problem, but it should be ruled out.
3Mb FTTC
Starmans
Is the DSL light not flashing at all? It should be lit and stable when connected but flashing while attempting to connect which is should retry every few minutes if it fails.
MatthewWheeler
Fixes: 479
I can see we're in the process of booking a appointment for tomorrow afternoon for you.
Let us know if you have any issues after that,
 Matthew Wheeler
Studio_Two
Quote from: Starmans
No, it never flashes at all. Permanently OFF.
Regards,
Stephen
Studio_Two
Quote from: godsell4
Thanks,
I'll have a look this evening.
Regards,
Stephen
Studio_Two
Quote from: Matthew
Hi.
The ticket status says the fault is back "in testing". Not sure what that means.
How much notice will I get if an appointment is booked? I have heard nothing as of yet, and will need to arrange to come out of work early.
Regards,
Stephen
MatthewWheeler
Fixes: 479
It's been confirmed for tomorrow afternoon between 1pm and 6pm.
 Matthew Wheeler
Studio_Two
Engineer has gone, but still no Broadband. DSL light is most definitely still OFF.
Very disappointing. Apparently, it should sync within 20 minutes, but he was on site for 2 hours.
dick:quote
MatthewWheeler
Fixes: 479
He's not passed the job back and he's raised a task from what I can see as the spare ports in the cabinet are faulty.
Let me check this for you.
 Matthew Wheeler
Studio_Two
Matthew, I would appreciate that. My parents sat in for me, so I couldn't speak to him directly.
Regards, Stephen.
dick:quote
MatthewWheeler
Fixes: 479
A engineers due to go out tomorrow to resolve the port issue.
 Matthew Wheeler
Studio_Two
Thanks Matthew,
Presumably they won't require access to my home?
dick:quote
Studio_Two
Attn moderator: It's kinda hard to quote less than a single line.
Strat
Fixes: 565
As the rule says you shouldn't be quoting anything from the immediately preceding post.
