Fibre connected tommorow
- Re: Fibre connected tommorow
27-01-2015 4:51 PM
Fibre is due to be connected tommorow with afternoon engineer visit. I already have broadband with a filtered socket fitted so will the engineer actually come to the address and do anything or just bring the modem? Also I've bought s bt hub 5 off someone on here as I don't want the modem and seperate router combo. Would the engineer connect it up with the hub rather than modem and router
Phil
Phil
Message 1 of 9
(1,084 Views)
8 REPLIES 8
27-01-2015 5:16 PM
Message 2 of 9
(522 Views)
27-01-2015 5:20 PM
Cool thanks save a lot of faffing with unplugging multiple cables at back of tv whereas is use hub 5 from off just need to uno,if sky one and plus in new one. Thank you
Message 3 of 9
(522 Views)
28-01-2015 6:19 PM
All connected and working nicely with hub5 at 36 ish via wifi. So all good.
Message 4 of 9
(522 Views)
28-01-2015 6:29 PM
Good evening,
I am glad you have things sorted.
I like the hh5 thinking of using one myself.
Message 5 of 9
(522 Views)
28-01-2015 9:18 PM
Quote I like the hh5 thinking of using one myself.
But what's wrong with the excellent PN supplied router, Joshua???
Message 6 of 9
(522 Views)
28-01-2015 10:21 PM
Can't commemt on supplied router as never connected it went straight to hub 5 which was easy and quick to setup. Do slightly wish I'd ordered faster. Didn't at time as was under impression could only get 43 but another check suggests I could get around 70.
Message 7 of 9
(522 Views)
28-01-2015 11:18 PM
Hi Psalliss
I'm glad your Hub 5 arrived and works okay.
You get 70mb if you take up the Fibre Extra package, I'm assuming you have Unlimited Fibre which gets you 40mb.
Did PN supply you the latest router or the older router?
NE
NE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 8 of 9
(522 Views)
28-01-2015 11:24 PM
Thanks ne. I think it's latest router but not sure.yes got unlimited fibre as when ordered it said fibre extra was available but expected speed was only 43 so didn't seem to make sense to pay all the extra money. But a different provider states can get 76
Message 9 of 9
(522 Views)
