Fibre broadband speed a disgrace
- Fibre broadband speed a disgrace
25-09-2015 7:14 PM
Download speedachieved during the test was - 2.57 Mbps
For your connection, the acceptable range of speedsis 20 Mbps-38.71 Mbps .
Additional Information:
IP Profile for your line is - 38.71 Mbps
Upload speed achieved during the test was - 1.21Mbps
Upstream Rate IP profile on your line is - 2 Mbps
Re: Fibre broadband speed a disgrace
26-09-2015 9:14 AM
What speed have Plusnet set your line to ? You can check it at this URL https://portal.plus.net/my.html?action=data_transfer_speed which will require you to log into your Plusnet Portal account.
It is not unusual for this to be left at the ADSL speed or even to go back to the ADSL speed.
If it does not show the fast FTTC speeds then you will need to contact Plusnet and get them to correct the "Plusnet Line Speed". Once at the correct speed, you will need to log onto your router and disconnect and reconnect back to get the speed increase.
And finally, there is no such thing on FTTC as a ten day settling period, that is an ADSL thing only. FTTC is at full speed once it has been set up and then checks all the time for line stability which will usually only decrease speed in favour of a reliable connection.
26-09-2015 10:34 AM
26-09-2015 11:24 AM
26-09-2015 11:27 AM
26-09-2015 11:32 AM
Quote Broadband Troubleshooter error
There's been a problem with our automated troubleshooting process.
Don't worry, our Faults Team will investigate it and be in touch. We'll aim to contact you within 24 hours.
[INTERNAL]Failure of Circuit Check[/unquote]
Estimated line speed:
40Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-08-31 14:54:55
Current line speed:
40 Mb
26-09-2015 11:34 AM
This test is probably more informative
http://www.thinkbroadband.com/speedtest.html
26-09-2015 11:43 AM
26-09-2015 11:51 AM
26-09-2015 12:46 PM
Quote Download speedachieved during the test was - 17.07 Mbps
Upload speed achieved during the test was - 1.83Mbps
Upstream Rate IP profile on your line is - 2 Mbps[/unquote]
26-09-2015 7:28 PM
Whoop, whoop! Alert! Alert!
Quote from: maxjam I am a radio ham operator
http://www.kitz.co.uk/adsl/rein.htm#HAM
http://www.arrl.org/dsl-interference
Just sayin'
26-09-2015 7:33 PM
[Moderator's note by Dick (Strat): Full quote of preceding post removed, as per Forum Rule]
26-09-2015 8:41 PM
I am not wrong. Ham radio transmissions can interefere with DSL.
Quote from: maxjam Yes well your wrong....I said I was a ham operagor I didn't say I was active..thank you very much..
What do you mean by 'inactive' - you only listen? You've given it up? Like most people I don't know anything about the particulars of the hobby. All I know is that ham radio transmissions can interfere with DSL signals so I felt it appropriate to post that warning as soon as you mentioned it.
I see no need for you to get all shirty about it. If you don't transmit then fine. If you have a lot of experience then fine. I don't know you from Adam so there's no way I could know either of those things. Just thank me for the advice and say that it doesn't apply in your case.
Sheesh. Some people.
26-09-2015 9:51 PM
Quote from: Andrue I am not wrong. Ham radio transmissions can interefere with DSL.
Ok then we can agree on the above.....but being 'responsible' it's one of the first things you look at if it's appropriate...I wasn't being shirty I just didn't appreciate the "Whoop,Whoop ! Alert ! Alert ! "...you were being condescending and patronising.....either way thank you for the helpful comments....regards
