Fibre broadband - slow speeds
duncum
I notice that I am having problems with low speeds. Opening web pages are very slow and down loading e-mails. Could some please check if all ok. Just carried out speed test only seeing 7 Mbps downloads
Problem not fixed just tried to add BT speed test results today still showing 7 Mbps downloads
duncum
Re: Fibre broadband - slow speeds
BT Speed Test Results
Fixes: 62
Fixes: 167
It's not dropping out a lot and the sync speeds are good. Everything on our side is set correctly too.
Testing the line is reporting an issue though, I can see you've reported a fault. We'll get that picked up asap.
Test Outcome Fail
Test Outcome Code GTC_FTTC_SERVICE_1624
Description Impairment in copper joint detected most likely close to customer premises. Please continue to submit a trouble report.
Main Fault Location CA
Sync Status In Sync
Downstream Speed 66.9 Mbps
Upstream Speed 20.0 Mbps
 Chris Parr
 Plusnet Staff
duncum
Thanks, All I need is BT engineer to look at the line speed has been bad since Saturday, maybe I can get a refund/credit on the lack of service from CS
Fixes: 167
Speed issues aren't something we generally refund for as the service is still working, albeit at a slower speed. Lets get the fault sorted and then see how long it took, we can look at a gesture of goodwill if applicable at that point.
 Chris Parr
 Plusnet Staff
duncum
Do you have a time frame when the fault can be looked at by the engineer and repaired?
Simon
duncum
Hi, Can you please update me when I can expect the fault on my line to be repaired?
Simon
Fixes: 167
We're going to need to book an appointment, if you can reply to the fault ticket here with your availability I'll get that booked in and confirmed asap.
 Chris Parr
 Plusnet Staff
duncum
Hi Chris,
I rebooted the system and just check the line and all is working ok!!
 So need to book a engineer at present, I will keep a eye on the line speed
Fixes: 167
No problem, I'll pass the fault ticket back to you and it'll remain open for 14 days to allow you to monitor, If you have any problems just reply to it and we'll pick it up.
 Chris Parr
 Plusnet Staff
Fixes: 167
Ignore the above, I can see you've closed the fault off.
 Chris Parr
 Plusnet Staff
duncum
I forgot that I could leave the ticket open for 14 days, If the fault occurs again I will raise a new ticket.
Thanks again
