Fibre broadband not guaranteed speed
Ibaile2
My contract is for a minimum 36mbps and it’s actually 6.2 download and 1.3 upload, slower than when it wasn’t fibre, this seems like just a way to make money, I’m about to renew my contract this needs sorting !
2 REPLIES 2
Champion
Fixes: 19
Re: Fibre broadband not guaranteed speed
@Ibaile2
Are you testing on a wired of WiFi connection. For this type of query it needs to be wired.
Login to your PlusNet account and then go to
www.plus.net/help/broadband/how-to-test-your-broadband-speed/
EdWeasley
Hi @Ibaile2,
Thank you for taking your time to get in touch.
I am very sorry that you are having a problem with your internet connection. I have tested your service and I can see that your services are running slow. I have created a question on your member centre with the tests needed to be completed. You can view this on the following link. https://www.plus.net/wizard/?p=view_question&id=200451691
Kind regards,
Josh
 Josh Berriman
