Fibre broadband is running slow
Andrea2006
Hi, my fibre is running really slow. It is meant to be approx 40mb but is running at 6mb. Can this be fixed?
Edit - I have raised a ticket. Number is 139780199 -
Andrea2006
Re: Fibre broadband is running slow
Can someone please look at this? I don't really expect to be paying for a service I ain't getting. No luck on phone either Sad
Fixes: 165
I've just gone to look in to the fault but it appears to be closed off. Are you still seeing problems?
I've tested your line and it's not showing any issues:
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 2.0 Mbps
 Chris Parr
 Plusnet Staff
