Fibre broadband is running slow
- Re: Fibre broadband is running slow
09-12-2016 6:33 PM - edited 09-12-2016 11:16 PM
Hi, my fibre is running really slow. It is meant to be approx 40mb but is running at 6mb. Can this be fixed?
Edit - I have raised a ticket. Number is 139780199 -
Message 1 of 3
(693 Views)
2 REPLIES 2
10-12-2016 9:58 PM
Can someone please look at this? I don't really expect to be paying for a service I ain't getting. No luck on phone either
Message 2 of 3
(641 Views)
13-12-2016 1:18 PM
I've just gone to look in to the fault but it appears to be closed off. Are you still seeing problems?
I've tested your line and it's not showing any issues:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0001 |
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 40.0 Mbps |
Upstream Speed | 2.0 Mbps |
Message 3 of 3
(579 Views)
