Fibre broadband constant dropouts
adam945
Fixes: 72
Re: Fibre broadband constant dropouts
I'm really sorry to see that the Major Service Issue is yet to be resolved @s1mps
Unfortunately as well, due to some recent changes within BT Wholesale / Openreach, we're unable to contact the Network Incidents Team any more for further updates. Our KBD states that the MSO was due to be addressed and reoslved by 02/08/2021 at 19:00, however no further updates are available at the moment.
Please accept our apologies for the inconvenience this has inevitably caused.
 Adam
 Plusnet Help Team - Leeds
adam945
Fixes: 72
Just another quick update @s1mps
Our team have managed to get in touch with the team that deals with Openreach IMT's, it's been confirmed that your service needs to be disassociated from the IMT. This matter has been sent across to our supplier's application support team in order to get progressed. We expect this to take 24 hours.
Thank you for your continued patience and understanding.
 Adam
Fixes: 1,283
Once that's happened we should then be able to properly test your line and raise a fault if needed  Smiley
