Fibre been down for 3 days, no update in 24 hours!
sketchmx
How long does it normally take to get a useful response from PlusNet via online fault logging?
After loosing my connection on Saturday (DSL light on but no activity) I reported fault on Sunday loads of updates about the call being booted around departments at plusnet but no actual useful update in nearly 24 hours, that's 3 days down now.
Swapped out all cables, replaced with plusnet router and open reach box (was using combined Draytek) and nothing.
A
Fixes: 167
Re: Fibre been down for 3 days, no update in 24 hours!
Give me a few minutes and I'll reply back here.
 Chris Parr
 Plusnet Staff
Fixes: 167
Hopefully that's sorted it? Let me know if you're still having problems.
 Chris Parr
 Plusnet Staff
sketchmx
Just popped out but will test when I get back, if that has fixed I should jut bypass support and post here, far quicker response Smiley
Thanks,
sketchmx
I can confirm that the issue is now resolve, thank you  Cheesy
