Fibre as bad as ADSL + Ping issues
MichaelBendikas
Hello i recently have changed to fibre, i kind of knew that my speeds would be the same, well i was expecting it to be a bit faster. I have problems with my ping when anyone in my house is streaming any sort of video or loading a hd picture ect, is this a problem that plusnet can fix or will i have to get a QoS router?
fibre:
http://www.speedtest.net/my-result/3851106725
ADSL:
http://www.speedtest.net/my-result/3814555130
10 REPLIES 10
Oldjim
Resting Legend
Fixes: 63
Re: Fibre as bad as ADSL + Ping issues
You need to post the information requested here excluding the router stats part http://community.plus.net/forum/index.php/topic,96155.0.html
MichaelBendikas
Bt speed test: http://i.imgur.com/TLChQLt.png
Estimated line speed:
6Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-09-26 13:31:16
Current line speed:
78 Mb
Oldjim
Resting Legend
Fixes: 63
https://www.btwholesale.com/includes/adsl/adsl.htm
Does this give any information about expected line speeds
MichaelBendikas
adamwalker
Fixes: 221
Hi  Michael.B,
You should be getting much better speeds than that.
I've just checked over your account, ran some diagnostics and ruled out anything obvious from and ISP and network point of view.
I'd urge you to report this as a fault with us as soon as you can: http://faults.plus.net
 Adam Walker
Oldjim
Resting Legend
Fixes: 63
Your speeds are right at the bottom of the impacted range so a fault report as Adam suggested is the way to go
MichaelBendikas
http://i.imgur.com/0CVhJPm.png Seems silly to me that i get worse speeds on fibre than adsl 😕
Also if i max out my download speed like this should my ping increase like this, and is there anyway of stopping this, because my games are awful when anyone in the house watches a youtube video: http://i.imgur.com/nrLR13A.png
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
I've not been able to find your account. Could you post your ticket number here and then I can ensure it's looked at again by either an experienced member of the faults team or by someone in CRT (us).
Thanks,
Tony
 Tony T
MichaelBendikas
The ticket ID was: 93475272 But i closed it by accident when i was trying to add a comment clicked the wrong button 😕
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Thanks for that. I've created a new ticket for you and raised it back to the faults team. I hope that with this, they'll be able to take this matter further and at least try to increase your speeds.
Tony
 Tony T
