Fibre Wireless V Wired speeds...help?
- Re: Fibre Wireless V Wired speeds...help?
19-07-2015 9:58 PM
So I got fiber installed and when using wireless I get 45MBPS, however if I use wired I get 75MBPS. This is what I should get.
Now I've tried to change the wifi broadcast channel on the Plusnet router that's connected to the BT modem and it makes no difference (yeah I tried all 13 channels)
I've also tried to switch off the cordless phones etc but it makes no difference. Oh I'm only about 4 meters away from the router that's in my hallway.
Any idea suggestions apart from using wired as I don't want a Ethernet cable running about my house or should I splash £50 on a powerline adapter?
Message 1 of 6
(783 Views)
5 REPLIES 5
19-07-2015 10:21 PM
What specification of wireless adapter does your computer have? You need N300 or better hardware to be able to use the full potential of the Plusnet router's wireless.
Message 2 of 6
(505 Views)
20-07-2015 10:54 AM
The options include:
- Accept that your wireless devices will only get around 45Mb/s maximum (apart from speedtests is there anything that actually requires a higher speed on a specific wireless device?).
- Use Powerline adapters (remember that some of these too may be limited in throughput).
- Add a decent wireless access point / wi-fi extender.
- Change to a better router with faster wi-fi (note this (and the previous suggestion) will only be of benefit if the connected devices support the faster wi-fi speeds).
- Ethernet! (I know, I'll get my coat now!).
Call me 'w23'
Message 3 of 6
(505 Views)
20-07-2015 5:25 PM
My laptop, PS4 and IPad should all handle the full download speed. I'm paying an extra £10 a month for the top speed but not getting it. The main reason is that I download a lot of games etc on PS4 and every little bit of extra speed helps.
Might opt for the power line adapters, you stated to change to a better router, doesn't the Plusnet provided one do the job?
dick:quote
dick:quote
Message 4 of 6
(505 Views)
20-07-2015 6:17 PM
Powerline adaptors *might* help but I've found that for me anyway they are slower than WiFi. My computer is on the first floor and Router downstairs in the living under the stairs. I had expected powerline adaptors to give me really good speed since I'm in a new build house with new wiring but seems not!
I would recommend looking at another router and comparing to powerline adaptors before just buying powerline adaptors
Speed on wifi:
Speed over powerline:
Speed on wifi:
Message 5 of 6
(505 Views)
20-07-2015 6:33 PM
Which iPad? Only the iPad Air appears to have 2x2 "up to 300Mbps" wireless, earlier models were had 1x1 150Mbps wireless, which in practice will operate at a maximum wireless rate of 65 or 72Mbps, which would probably be sufficient for download speeds and speedtest results of around 45Mbps. PS4 has 2x2 "up to 300Mbps" wireless.
Message 6 of 6
(505 Views)
