Fibre Up to 76Mb
FIXED- Subscribe to RSS Feed
- Fibre Up to 76Mb
21-03-2017 11:54 PM
I have looked to see if I can upgrade my fibre, but dont have any options other than the one i am currently on.
Offering 21Mb - 27Mb
But when I goto uswitch I see BT offering
BT Infinity Fibre 2 Unlimited Broadband & Calls
as up to 76Mb.
Am I missing something?
Fixed! Go to the fix.
22-03-2017 12:04 AM
Yes, of course you are missing something!
Much will depend on how far you are from the exchange if you want BTW provided services - put your phone number/ post code into dsl checker it will tell you the max speeds you can expect via BTW.
Virgin may be able to provide higher speeds, if service is available..
Re: Fibre Up to 76Mb
22-03-2017 12:13 AM
Max on dsl checker is 27mbps.
