Fibre Unlimited Service Degrading
FIXED- Subscribe to RSS Feed
- Fibre Unlimited Service Degrading
11-03-2019 11:34 AM
Fixed! Go to the fix.
Re: Fibre Unlimited Service Degrading
11-03-2019 2:31 PM
Hi Malcolm.
Our tests are showing your speeds restricted by the dynamic line management(DLM) software at the exchange with no obvious causes for this, so I've arranged for your line to be reset.
I'd allow 72 hours for this to go through and if your speeds haven't improved following this, I'd recommend raising a fault to us at http://faults.plus.net letting us know over here once you've completed it, so we can pick this up as soon as we can and arrange an engineer visit for further investigation.
Hope this helps.
11-03-2019 3:23 PM
Hi Anoush
Many thanks for the swift reply. I did a Speedtest at a pub at the weekend which is 300m closer to the cabinet and even in the bar using their Wi-Fi the download speed was 45mbs! I will wait for 72 hours as you suggest.
Thanks again.
Regards
Malcolm
11-03-2019 3:45 PM
14-03-2019 1:41 PM - edited 14-03-2019 1:42 PM
14-03-2019 4:55 PM
Hi Anoush. I’ve just done a speedtest and it recorded 30mbs download which is great. Many thanks for your help. Have you any idea why the line was restricted by the DLM?
Regards
Malcolm
14-03-2019 5:28 PM
Hi Malcolm,
It's not always possible to identify why a line would become banded, only that it is (was) and that action should be taken to remove the banding.
I'm glad that this is now sorted for you - please let me know if there's anything else you need.
Best wishes
Dave
