Fibre Unlimited Service Degrading
morsoft
Hi. I first changed to Fibre 3.5 years ago and was initially getting 32mbs download speed which I was happy with. However the service degraded over the first year but was still getting around 28 mbs. For the last year it has gone down to 24mbs but seemed stable at that. Unfortunately over the last few months it has dropped to 16mbs which is half what I was initially getting and this is now creating problems with BT sport channels and other internet channels. I would be grateful if somebody could help. Malcolm
6 REPLIES 6
Fixes: 580
Re: Fibre Unlimited Service Degrading
Hi Malcolm.
Our tests are showing your speeds restricted by the dynamic line management(DLM) software at the exchange with no obvious causes for this, so I've arranged for your line to be reset.
I'd allow 72 hours for this to go through and if your speeds haven't improved following this, I'd recommend raising a fault to us at http://faults.plus.net letting us know over here once you've completed it, so we can pick this up as soon as we can and arrange an engineer visit for further investigation.
Hope this helps.
morsoft
Hi Anoush
Many thanks for the swift reply. I did a Speedtest at a pub at the weekend which is 300m closer to the cabinet and even in the bar using their Wi-Fi the download speed was 45mbs! I will wait for 72 hours as you suggest.
Thanks again.
Regards
Malcolm
Fixes: 580
No problem Malcolm, fingers crossed your speeds improve soon.
Fixes: 580
Hey Malcolm,
I've just checked back and tested your line and it looks like your speeds have increased to around 32mbps now.
Are you seeing an increase on your side?
morsoft
Hi Anoush. I’ve just done a speedtest and it recorded 30mbs download which is great. Many thanks for your help. Have you any idea why the line was restricted by the DLM?
Regards
Malcolm
Fixes: 34
Hi Malcolm,
It's not always possible to identify why a line would become banded, only that it is (was) and that action should be taken to remove the banding.
I'm glad that this is now sorted for you - please let me know if there's anything else you need.
Best wishes
Dave
 Dave G
