Fibre Streaming
- Re: Fibre Streaming
Fibre Streaming
23-12-2014 1:42 PM
Edit - Btw I'm using the PlusNet fibre router and ECI Openreach modem and my devices are LAN cabled to the PlusNet router. Wireless is off.
Re: Fibre Streaming
23-12-2014 2:08 PM
I get 70mb down with 17mb up, yet when uploading through a cloud app, it was capping me at 2mb, instead of the 17mb I should get....
I asked on here to remove the stealth/hidden traffic shape, but am told there is none......
Strange eh !
**to note:
The cloud is my own, so the client was a virgin 50mb, and a PlusNet ADSL 13mb, either machine that downloaded data from me was capped at 2mb, or 232kb a sec, same applies when using FTP, max out at 273kb a sec **
Re: Fibre Streaming
23-12-2014 2:12 PM
as for the OP, sky on-demand services impose a bandwidth limit so it will only get so fast and then top out - it's well below what your 38Mbps connection is able to handle.
Re: Fibre Streaming
23-12-2014 2:24 PM
I wonder about what the Pro add-on does and whether it's worth having? CS always seem to say to me take it off as I don't need it when I speak to them. But if you want snappy browsing and good streaming maybe it might be worth having even on fibre?
Re: Fibre Streaming
23-12-2014 2:26 PM
QoS has to be applied for services like those.
the pro add-on would make no difference in this situation as it is not a plusnet restriction.
Re: Fibre Streaming
24-12-2014 2:08 PM
@woodm
I've just made a few checks and ran some diagnostics and can't see an obvious reason from our POV why you might be seeing those issues.
It might be worth as a test connecting a PC straight to the modem, bypassing the router just to rule that out of the equation.
Re: Fibre Streaming
24-12-2014 2:55 PM
Re: Fibre Streaming
24-12-2014 3:01 PM
Re: Fibre Streaming
24-12-2014 3:01 PM
sky limit the bandwidth available so you'll never get anywhere near your max fibre downstream rate when using it.
Re: Fibre Streaming
25-12-2014 12:34 AM
Re: Fibre Streaming
25-12-2014 9:52 AM
