Fibre Stability
- Fibre Stability
Fibre Stability
10-09-2015 2:55 PM
I must have had at least 8 new connections since Monday (since my fibre was installed. At least two, possibly three of those were my own doing as I rebooted the modem when I found myself on a slow gateway and also when my product was moved from 40/2 to 80/20. But that leaves at least four or five new connections in the last few days. Is this normal for fibre and/or the OR modem?
Re: Fibre Stability
13-09-2015 5:28 PM
Re: Fibre Stability
13-09-2015 5:30 PM
Has your IP Profile changed at all?
Re: Fibre Stability
13-09-2015 5:44 PM
My IP profile has remained fairly constant at around 63Mbps. I say "around" as I think it was 64 yesterday but can't be sure.
My line's been stable for the last 48 hours, the longest so far, and I've been recording consistent speeds of c62.5 down and 14 up, which I'm quite happy with (especially as my original estimate was 54 down). But just after 4pm this afternoon it seems my IP address reset again and now I'm recording only 17.6 down and 12.81 up. Before I was on 37.152.xxx.x and now I'm on 91.125.xxx.x. Not happy with current speed that's for sure
Re: Fibre Stability
13-09-2015 7:10 PM
that said you shouldn't be dropping connection like you are so something isn't right
Go here run the test ignore the red writing, http://speedtest.btwholesale.com/
when it's complete pick further diagnostics enter your phone number and copy & paste what it says
then go here https://portal.plus.net/my.html?action=data_transfer_speed ; login to your account and it will state what your current line speed is set to on plusnets end so post that here to
the above could give some indication as to whether your dropping sync to the fibre cab or just the session to plusnet.
Re: Fibre Stability
13-09-2015 7:14 PM
1. Best Effort Test: -provides background information.
Download Speed
17.6 Mbps
0 Mbps 63.13 Mbps
Max Achievable Speed
Download speedachieved during the test was - 17.6 Mbps
For your connection, the acceptable range of speedsis 44.19 Mbps-63.13 Mbps .
Additional Information:
IP Profile for your line is - 63.13 Mbps
Upload Speed
12.81 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 12.81Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
My current line speed according to PlusNet is 63Mbps, which to be fair I was getting until this afternoon
Re: Fibre Stability
13-09-2015 7:18 PM
Re: Fibre Stability
13-09-2015 7:19 PM
If it doesn't self correct soon I'll reboot the router, but even if it does e.g. get me on a better gateway I'm still curious as to why it disconnects as often as it does
Re: Fibre Stability
13-09-2015 7:30 PM
well the speedtest reports the following:
and I've just run the BT test again which shows:
Download Speed
60.26 Mbps
0 Mbps 63.13 Mbps
Download speedachieved during the test was - 60.26 Mbps
Upload Speed
12.6 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 12.6Mbps
We were unable to identify any performance problem with your service at this time.
...so I can only guess that it was a temporary thing. Happy the speed seems to have corrected itself but why would I have such fluctuations and instability?
Re: Fibre Stability
13-09-2015 7:34 PM
Re: Fibre Stability
13-09-2015 7:40 PM
Re: Fibre Stability
13-09-2015 10:28 PM
you could try a factory reset on it see if that sorts out anything if it doesn't then I would ask plusnet for a replacement it shouldn't be dropping session like that.
Re: Fibre Stability
13-09-2015 10:34 PM
