Fibre Speeds
superuser
Fibre Speeds
Been on Broadband for years and am not far from the Cab
ADSL MAX always gave me close to the MAX 20MB
I went to Fibre (Standard) 40MB and that's near enough what I got
Later I switched to Fibre MAX and was estimated 70MB
But it's been quite a few months (over 6 actually) and it's still not moved over the 40MB
Tell me what you need and I'll get to it. Sometimes takes me a day or so as I have very busy work etc..
p.s
The Open reach modem is in place and the PN router, basically the default stuff...
PeeGee
Re: Fibre Speeds
What is your current line profile (you will need to login)?
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Using a TP-Link TD-W9980 modem-router.
superuser
Re: Fibre Speeds
Estimated line speed:There's no speed estimate currently held on your account.Current line speed:42.4 Mb
Fixes: 162
Re: Fibre Speeds
Looking in to this, will post back shortly.
 Chris Parr
 Plusnet Staff
Fixes: 162
Re: Fibre Speeds
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 73.2 57 20 15.3 -- Available -- --
VDSL Range B (Impacted) 56.4 32.4 16.6 7.2 -- Available -- --
Your line is currently synced below the estimates for your line, which can be seen above. Your current connection speed is shown below:
Main Fault Location OK
Sync Status In Sync
Downstream Speed 43.9 Mbps
Upstream Speed 20.0 Mbps
I'd recommend getting this reported as a fault for further investigation at https://faults.plus.net
 Chris Parr
 Plusnet Staff
superuser
Re: Fibre Speeds
Fault raised and in process
Fixes: 162
Re: Fibre Speeds
Our faults team will pick that up and get in touch asap.
 Chris Parr
 Plusnet Staff
superuser
Re: Fibre Speeds
ON the 7th, I had a message as quoted below, but not much seems to be happening, except I have noticed my internet loosing connection from time to time
We are currently performing tests on your broadband service which will allow us to investigate the problem you've reported.
Please be aware if this is a new fault that this can take up to 24 hours.
We'll contact you as soon as we have more information and let you know what happens next.
superuser
Re: Fibre Speeds
KBD
KBD
BRAS adsl35000 Profile Info N/A
NF507 - No issues have been identified in the BTW network. KBD tests indicate no BTW network fault. Please perform all CP and End User checks. BTW Performance/Speed test has not been run.
PTTR
Response
No records found
GEA Service Test
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Appointment Required N
NTE Power Status PowerOn
Sync Status In Sync
Upstream Speed 20.0
Profile Name 0.128M-44M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Copper Line Test Pass
Bridge Tap Not Detected
Radio Frequency Ingress
REIN Not Detected
Cross Talk
Workplace and Radius
WP Product: WBC FTTC Annex A 20Mbit/s Up, 80Mbit/s Down, Standard Stability
WP Profile: Generic Speed 42400 Time Out
Ellacoya: Service_Offer_66
Connected for One Day, 23:43:20
0 drops in last 24 hours
2 drops in last 72 hours
1 of 2 (50%) User Req Drops in last 7 days
https://visualradius.plus.net/visualradius/generated/image14680803547049.png
TagsTelephone Number on Exchange ARNSIDE is served by Cabinet 3
Featured Products
Left in Jumper
  High Low High Low
Summary*Raising for SFI to clear cap on the line
Fixes: 162
Re: Fibre Speeds
Looks like the faults team are arranging an engineer in order to reset the line, unfortunately we can't do this remotely.
 Chris Parr
 Plusnet Staff
superuser
Re: Fibre Speeds
Right.
TBH. It was all a little worrying because they just go on about charging me if it it's my fault.
Well everything's default what openreach guy put in originally
superuser
Re: Fibre Speeds
So the OR engineer came and reset the line (14 July)
He found no fault with the stuff in my home
The line profile requested at the start of this thread remains the same, I just checked (15 July)
I'm starting to feel like a refund is in order TBH
I'm paying for something I ain't getting and have been for some time.
superuser
Re: Fibre Speeds
Estimated line speed:There's no speed estimate currently held on your account.Current line speed:63 Mb
Improvement
