Fibre Speeds down to 2MB
- Re: Fibre Speeds down to 2MB
20-06-2015 11:11 AM
Im new to Plusnet regards my fibre but my expected speed should be 75MB.
In reality i have to keep disconnecting and switching off the router then restart to achieve 45MB......whislt i don't expect to get 75MB......2MB is proving difficult. After an hour is crawls down to 2MB.
I've tried all the tips but still no better.
Thoughts?
Thoughts?
Message 1 of 7
(998 Views)
6 REPLIES 6
20-06-2015 11:46 AM
Your not turning the modem on and off are you because it will cause dlm to kick in.
Message 2 of 7
(681 Views)
20-06-2015 11:53 AM
Thanks....well that what the plusnet guide tells me to do.
So keep it on at all times even when the speed drops to 2mb....thats the problem it then stays at 2MB.
Message 3 of 7
(681 Views)
20-06-2015 11:59 AM
The modem and router are 2 different things, turning off the router is a safer option but the openreach modem should be left on at all times if you can as it could mess up the speeds on your line. you need to let DLM adjust your line over the coming days and bring your speeds up, it is thinking you have a fault on your line with you turning it on and off.
Message 4 of 7
(681 Views)
20-06-2015 12:00 PM
Ok.... cool...i will give that a whirl.
Thanks again.
Thanks again.
Message 5 of 7
(681 Views)
22-06-2015 10:31 AM
Message 6 of 7
(681 Views)
06-07-2015 7:27 PM
Quote from: damobolton Ok.... cool...i will give that a whirl
Have you seen an improvement since this now?
Message 7 of 7
(681 Views)
