Fibre Speed
- Fibre Speed
Fibre Speed
02-05-2020 11:14 AM
Hi all,
I recently posted because my line kept dropping quite a bit, so last week i started using a new router (BT home hub 6). This seems to be a more stable connection with not as many dropouts, however my speeds are really low and much lower than they should be as i was getting close to 36mb download before and now i'm only getting 8-10mb. I just ran the BT wholesale speed test, through an ethernet connection as recommended and it came back with 8.34mb download speed and 1.86 upload speed. According to the further diagnostics report the IP profile for my line for downloads is set to only 9.18mb and my upload IP profile is 10mb. I've included a copy of this report.
Can someone look into this for me please?
Thanks very much.
Re: Fibre Speed
02-05-2020 12:05 PM
Try switching the Smarthub 6 off using the switch on the back of the hub. Leave it a minute then switch it back on.
I have seen a similar problem once and put it down to a start up issue when switching on at the mains.
Re: Fibre Speed
02-05-2020 12:21 PM
Re: Fibre Speed
04-05-2020 2:02 PM
Hi @Davemorris1951,
Thank you for taking your time to get in touch.
I am very sorry that you are having a problem with our service. Together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in Speed Faults being fixed. In the meantime, please raise your speed fault online at faults.plus.net.
Kind regards,
Josh
Re: Fibre Speed
04-05-2020 6:06 PM
Re: Fibre Speed
16-05-2020 7:14 AM
