Fibre Speed
FIXED- Subscribe to RSS Feed
- Fibre Speed
04-08-2017 3:33 PM
Is it possible for a profile reset on my connection? Not sure if there is a DLM on the connection. I've checked my speed and it at 18.7Mbs Down, When I started on fibre couple year ago I was at 26-28Mbs Down. It dropped to 22-23Mbs last year and now over the last couple of months it's gradually got to 18-19Mbs Down. Upon checking the DSL Checker the speeds are between 22-31Mbs Image will explain in the red box. Also while I'm here every now and then I get a PPP connection drop which is seen on my TP-Link Router any ideas on that?
Fixed! Go to the fix.
Re: Fibre Speed
08-08-2017 12:16 PM - edited 08-08-2017 12:19 PM
Unfortunately we can't remotely reset profiles on a fibre line.
I'm just checking your line and will add more to this reply shortly.
The estimates for your line are:
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
WBC FTTC 18x2 Provide Availability |
WBC FTTC 18x2 Sim Availability |
Left in Jumper |
High | Low | High | Low | |||||||
VDSL Range A (Clean) | 31 | 22.4 | 6.9 | 4.9 | 20 | Available | -- | Yes | Yes | -- |
Your line is currently connected at:
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0003 | ||||
Description | No problem found, OAM test is not currently supported on this line. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 20.0 Mbps | ||||
Upstream Speed | 2.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 1189.1 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Low | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-20M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off | ||||
Time Stamp | 2017-07-26T12:30:00 |
I'd advise getting this reported to us as a fault at https://faults.plus.net
Re: Fibre Speed
08-08-2017 2:37 PM
Hi Chris,
Thank you for checking my line for issues/faults. I've read through and now followed up as a fault. I've done more speedtest also seems I'm blocked? using the BT Speedtest? also to verify I did a test on SpeedTest all done under Ethernet.
Re: Fibre Speed
11-08-2017 1:09 PM
Anyone able to check up on my fault that I raised on the 8th August? It's been three days and had so such reply or anything, in the past this used to be rather quick process but can understand if there a big queue of faults raised. Since the 8th been left this as a response.
"We are currently performing tests on your broadband service which will allow us to investigate the problem you've reported. We'll contact you as soon as we have more information and let you know what happens next."
Any updates on the matter would be grand.
12-08-2017 3:43 PM
Re: Fibre Speed
12-08-2017 7:05 PM
Thank you for your reply, I've replied to the fault question with my preferred timeslot and days.
Re: Fibre Speed
13-08-2017 9:43 AM
Re: Fibre Speed
15-08-2017 3:46 PM - edited 15-08-2017 3:48 PM
OpenReach Engineer visited today grand chap called John. He did a few checks with the master socket and said the fault not to be internal (Inside my house), A broken cable underground after inspection was the cause and he replaced it and sorted it at the cabinet end. More tests were done and DLA was reset and now synced at 31Mbps Down and 2Mbps Up.
Thank you for helping me on this issue happy to have my internet back to full speed. Could I have one final GEA Test please underneath this post for my own record.
Re: Fibre Speed
17-08-2017 4:43 PM
Happy to hear that!
Sure thing, here you go:
Downstream Speed | 30.8 Mbps |
Estimated Line Length In Metres | 1160.5 |
Downstream Rate Assessment | Good |
Interference Pattern | Regular Interference Observed on Week Days |
Interference Duration Longest Occurrence | From 18:15 to 19:30 |
Interference Location | Customer Premise |
Interference Observed In Days | 3 |
Technology | VDSL |
Profile Name | 0.128M-40M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off |
