Fibre Speed
- Re: Fibre Speed
Fibre Speed
19-07-2017 6:58 AM
Currently my router shows:
Connected : Down Stream : 45352Kbps / Up Stream : 12796Kbps |
From my PlusNet account I get:
Telephone number:01539736*** Phone exchange:KENDAL Estimated line speed:77Mb (This may vary between 58.3Mb and 77.8Mb) - Checked on 2017-06-20 14:07:29 Current line speed:78 Mb
Plugged in to the master socked
Dratek Router
I was expecting better than this really?
Only moved in 2 weeks ago, but thought it might have settled by now?
Any ideas
Re: Fibre Speed
19-07-2017 12:37 PM
My tests are showing your router in sync below the estimated speed for your line.
Sync Status | In Sync |
Downstream Speed | 45.4 Mbps |
Upstream Speed | 12.8 Mbps |
Things are pointing towards a line fault.
Voice Line Test Result | Voice fault suspected - contact Voice CP to progress copper issue |
Testing the line itself has identified a possible Earth Contact on the line. I've reported this through to Openreach now. We'd expect an update within the next 48 hours. Our faults team will follow up via this ticket
Re: Fibre Speed
19-07-2017 3:47 PM
Wow
So BT came the same day I mention this here!
Glad a I came back to PN again after my house move.
The fault is outside underground somewhere. They have to get someone else to pin point it with a view to digging to it. They think water is getting in
Re: Fibre Speed
20-07-2017 8:39 AM
Re: Fibre Speed
24-07-2017 6:38 AM
I have received confirmation that the fault is now fixed.
As for the issue with speed, I may have to wait and see. My router is still showing similar sync to before, but I didn't disconnect and reconnect yet, just wanted to let it settle down for a week and then try. There has been far too much on/off with openreach playing with it.
I'll report back soon with an update
Re: Fibre Speed
24-07-2017 1:59 PM
Re: Fibre Speed
25-07-2017 6:04 AM
We are not actually using the telephone, only the Internet so can't comment
General browsing is OK but some in the house complain of lousy gaming experience
Re: Fibre Speed
25-07-2017 12:14 PM
Re: Fibre Speed
on 29-07-2017 6:57 AM - last edited on 29-07-2017 7:22 AM by Mav
Openreach came and went on Wednesday and apparently turned up again yesterday (Friday), I was out.
Anyway, they keep coming up with different earthing faults and the engineer yesterday said he needs to access the line where it comes in to the property, but it requires lifting some block paving and they don't do that, but use contractors.
Anyway, PN also messaged me asking me to book an engineer appointment.
Honestly though I'm not entirely sure there isn't some mixup. I got the old 'it will cost you speech, if the fault is in your property' and an engineer is booked for Tuesday AM.
But they already checked the property line and stuff twice, all without me even asking, and without the 'it will cost you' blah.
I think what thy actually want to do is connect to the line at point of entry and check back up the line.
The BT original master is in the Living Room, but I'm quite happy for them to put a new one in the hall, where the BT line hits the house.
Please make sure the booked engineer is not wasting his time, checking my Master Socket again. What we are after is what the engineer said yesterday, to begin access to the point of entry.
Moderator's note by Mike (Mav): Post released from Spam Filter
Re: Fibre Speed
31-07-2017 11:34 AM
Re: Fibre Speed
01-08-2017 7:40 PM
Interestingly, the engineer reported that the performance at some part of the Cabinet was questionable.
We did find the BT line in on the outside of the house was poor and damp. This was repaired.
The engineer also questioned the possible speeds for my line based on PN estimation, saying I might only get 50 down at best.
Strange because I'm half the distance from the Cab compared to my previous home, that ran reliably in high 60's down.
I guess I'll let things settle down, but I'd like to know that the Cabinet was performing properly, which apparently it wasn't.
Currently
Connected : Down Stream : 47756Kbps / Up Stream : 14332Kbps |
Re: Fibre Speed
02-08-2017 6:12 AM
I should add too.
Regarding the cabinet, the engineer made a test there, direct to it and said he should be getting 150, but it was actually only pushing 90. He also connected a 600m cable, a new roll to check what was coming out on that distance and it was around what my current rate is quoted above.
So he mentioned so stuff that should be checked in the cabinet but that he wasn't out to fix it, because he was looking at getting the line fault clear, which we think it now is.
He suggested I report a broadband fault to have an engineer look at the issue in the cabinet, you guys may know more about what he means. But can we please get it looked at.
Thanks for the great support
Re: Fibre Speed
02-08-2017 1:46 PM
Re: Fibre Speed
05-08-2017 9:01 PM
I did all this and I think it's logged a fault post test
Re: Fibre Speed
08-08-2017 1:42 PM
Looks like one of my colleagues in the faults team is testing your line and working on your fault today.
