Fibre - Speed well below line sync speed?
cvpiper
Hi
Unable to get hold of customer services in work hours. Can somebody help what I need to get done?
Line Sync Speed - 60 MBps
Min Guaranteed Speed - 30 MBps
Current Actual Speed - 20 MBps
Also the current speed showing on PlusNet site, I.e. below the minimum. How do I get this rectified?
Thanks in advance
4 REPLIES 4
Fixes: 418
Re: Fibre - Speed well below line sync speed?
@cvpiper
Have you done the tests listed in this post?  https://community.plus.net/t5/Fibre-Broadband/Unlimited-Fibre-Extra-not-at-current-line-speed/m-p/17...
cvpiper
@Baldrick1 thank you for the reply. Yes tried all those and basics like different cable from the final part of connection.
No faults on site here Sad
Fixes: 418
@cvpiper
The easiest step is to report a fault at faults.plus.net.
cvpiper
Thanks will do that when its back up and running perhaps Monday....
