Fibre-Speed Slow
nkhan786
Fibre-Speed Slow
My router arrived a week ago or so and I was told my line will be activated by 06/04/2016. But I revived a text on the 5th saying it's been activated. I set up my router and since then I've only been recieving speed from 4-18mb but I'm paying for fibre extra speeds. Help?
Fixes: 238
Re: Fibre-Speed Slow
I'm just running a few tests for you.
Can you confirm that you've got the Hub One connected to the master socket like either of the below images?
router-ssfp-phone
router-microfilter-phone
 Matthew Wheeler
nkhan786
Yes I can confirm image 2
Fixes: 36
Are you checking the speeds via a wired connection or wireless?
nkhan786
Wired with every device off and still not reaching the speeds I paid for. My line check shows that I can receive up to 80mb aswell but I'm no where near it
Fixes: 238
Your sync speeds are a bit intermittent at the moment.
Can you test it in the next 15 minutes?
 Matthew Wheeler
nkhan786
Yeah I'll try in 15 minutes and post it here
NorthEasterner
Possible to test using the test socket behind the master socket?
Regards, NE
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
nkhan786
I've ran 4 tests and they're all inconsistent. Varies from 10, 18, 28 and 32. Different everytime but still not close to the fibre extra I'm paying for
nkhan786
I'm not sure how to do that
NorthEasterner
One second. I'll find you a diagram.
NorthEasterner
Here you go. Please see attachment.
NE
Fixes: 36
You can also find details in the Help Centre here
etdsaunders
Fixes: 7
What speeds should you be getting? You state you pay for the extra package, what estimates did you get during sign up?
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
nkhan786
I should be getting 74 my line checks say I can receive 80, I will be satisfied with anything near even 60/70 because I know you can't exactly get the whole total there are many factors which affect it
