Fibre Speed Dissappointing
- Fibre Speed Dissappointing
27-02-2018 5:19 PM
I've now had Fibre to the Cabinet upgrade for 32 hours and have only a minimal speed increase from ADSL. I set up the new router as soon as it arrived knowing it would work under ADSL. At about 08:55 yesterday the router stats showed it had rebooted to VDSL with almost no interruption to the service (despite PlusNet emailing that the service went live just after the previous midnight.
The ADSL speed was 15.17Mbps. The VDSL now 18.12Mbps (after a few minute run at 20.13Mbps).
Nothing else has been changed. All the equipment, filters, router and wiring are unchanged.
The upgrade notification and BT Availability Checker show speeds between 32Mbps & 44Mbps (Clean).
But I've just run the BT Wholesale Checker and it says the Max Achievable Speed is 17.54Mbps.
Have I been connected wrongly?
ps I'm assuming that rebooting the router won't help.
Re: Fibre Speed Dissappointing
27-02-2018 5:21 PM
27-02-2018 5:50 PM
Thanks.
I've just had a text saying I should reply with three time slots for an engineer visit. But as nothing has changed locally I'm not sure why this process has been selected. Everything in the house is exactly as it was (even the same filters are gathering dust in the same position). The only change is the fibre to the cabinet some distance from my undisturbed house.
27-02-2018 5:55 PM
Filters - implying you've got more than one - is much more of a problem for VDSL2 than it is for ADSL.
Try the test socket if you have one.
27-02-2018 6:08 PM
I don't have a test socket. Just the old single output (with an iPlate insertion several years ago) and one filter here plus a filter on the bedroom extension (which just has a backup traditional phone)
27-02-2018 6:21 PM
But an iPlate fits onto the test socket, so I'm confused about how you could have an iPlate and no test socket.
27-02-2018 6:33 PM
OK. Maybe my terminology is wrong?
It was fitted with a plate to improve the bell wire problem. The Master Socket is probably over 20 years old.
27-02-2018 6:52 PM
Does your master socket look like the one pictured here?
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
27-02-2018 8:06 PM
No.
It looks like the third item here (headed Master Socket with single socket)
http://bt.custhelp.com/app/answers/detail/a_id/40812/~/what-type-of-master-socket-have-i-got%3F
27-02-2018 8:53 PM
That looks fine, all you have to do is remove the screws, take off the front plate and iPlate, and then the test socket is under that.
28-02-2018 4:25 PM
Seems the profile has been set low. Yesterday 17.54 but today after an automatic reboot it's crept up to 20.47Mbps. BT are working on it.
28-02-2018 6:31 PM
The IP Profile value is set according to whatever speed your modem manages to connect at, not the other way around. The IP Profile value does not control or restrict the speed your modem may connect at.
02-03-2018 12:36 PM
UPDATE
It seems the automatic processes are doing their bit to fix this (while the engineer is still booked for Thursday 8th).
The line speed reset itself on Wednesday about 48 hours after installation. It went up from 18.12Mbps to 21.18Mbps. Then this morning (another 48 hours) it rebooted again to 23.59Mbps. Each time the profile has changed in the sequence of:- 17.54, 20.47, 21.45.
I understand that this is the BT kit doing this. So perhaps it is on a very slow upgrade path. Will it get to the proper speed in 48 Hour changes?
02-03-2018 12:58 PM
I think it's unlikely that the speed will gradually increase to somewhere between the 30 and 40 Mb of your estimate.
Did you try the test socket? Have you considered replacing the iPlate with an Openreach MK3 filtered faceplate?
02-03-2018 3:33 PM
I'm sure the test socket will improve something but as I said in the first post; the wiring at my end is exactly as it was under ADSL. I've been unable to find any other information to support the idea that the filters are worse under VDSl than ADSL.
So I'm working on the assumption that the new fibre circuit is at fault and the copper to the house and in the house is unchanged.
