Fibre Speed Check
- Re: Fibre Speed Check
Fibre Speed Check
06-11-2017 4:04 PM
Today I've had my upload speed changed from 1.9Mb/s to 7.5Mb/s as part of PlusNet's "Welcome to faster upload speeds for Unlimited Fibre". A relief for me as the slow uploads are now faster which is thankful. Could I squeeze that little extra out of my download or is this result wrong?
So I've ran 3 SpeedTests with BT Wholesale SpeedTest and I get 29.9Mb/s out of a max of 35Mb/s Download and a 6.5Mb/s our of a 2Mb/s Upload (Profile hasn't change)...
I've ran 2 speedtests with Speedtest and I get the Max of 29.7Mb/s Download and Max of 7.5Mb/s Upload which seems to be odd against the BT Wholesale Result. I checked with the BT DSL Checker and everything seems to be the same as what the BT Wholesale Speedtest says. Could I have a GEA Result if possible as I'm getting mixed results also I've attached three images Wholesale Result, DSL Checker and Speedtest.
07-11-2017 2:46 PM
Looking at the speeds you're getting vs the estimates for your line, this appears to be performing very well and well within the estimates.
You may be able to squeeze a little more by ensuring the router is in the master socket, using a wired connection etc but other than that it looks good.
