Fibre Slowly Slipping Away
r2obd
Another user with decreasing speeds, currently at 4.5MB Down at best and 0.7MB UP (started at 9MB at first sign up then to 8MB with in a week down to 7MB for a while now we are at 4.5MB) .  results as below from tests:
  Download Speed
  4.26 Mbps
0 Mbps 6.14 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 4.26 Mbps
 For your connection, the acceptable range of speedsis 4.3 Mbps-6.14 Mbps .
 Additional Information:
 IP Profile for your line is - 6.14 Mbps
Telephone number:
[Removed]
Phone exchange:
AYLSHAM
Estimated line speed:
10Mb (This may vary between 7Mb and 10.8Mb) - Checked on 2016-07-21 21:41:55
Current line speed:
4.5 Mb
Can you guys see anything up your end? - I'm guessing its just the Openreach infrastructure failing me like it fails most of us...
Moderator's note by Mike (Mav): Personal information removed from a public forum.
1 REPLY
Fixes: 34
Re: Fibre Slowly Slipping Away
@r2obd - Best to remove your phone number on a public forum.
