Fibre Router
davidjps
Fibre Router
Hi.
I have just received a text saying my router is in the post for my installation on Friday.
Can you tell me if you send them 1st or 2nd class and if I have to be in to sign for it, or will if fit  through my letterbox?
David.
Joshc
Re: Fibre Router
Good Morning,
Thanks for your inquiry.
They are sent first class and no you should not have to sign for it, it should fit nicely through your letter box.
davidjps
Re: Fibre Router
Thank You  Smiley
Joshc
Re: Fibre Router
That's alright
Have a good day  Grin
