Fibre Router with WAP
- Fibre Router with WAP
27-11-2014 11:03 PM
Cannot get the sound system connect asks us to press the WAP BUTTON to pair which appears not to be on the Plusnet router same with the wireless printer, though the printer menu does suggest it can be paired by using a code but that's beyong your average 60 year old.
Need something plug and play here ASAP so missing our AirPlay and having to print out any necassary docs at work.
Re: Fibre Router with WAP
27-11-2014 11:10 PM
27-11-2014 11:15 PM
My plusnet fibre router has a WAP button
To be is to do - Kant
do be do be do - Sinatra
28-11-2014 8:14 AM
That's a shame, you could have reused it on PlusNet.
Quote That should read home hub 5, which we have disposed of
28-11-2014 8:19 AM
28-11-2014 8:31 AM
28-11-2014 8:32 AM
WAP was the mobile data standard before HSDPA when mobiles first came out in the 80s.
Mine has one - to the far right those look like clear panels but they are buttons. Press it for a second and it should flash orange and then you can go ahead.
28-11-2014 9:11 AM
