Fibre Plus speed is Slow
- Re: Fibre Plus speed is Slow
02-09-2017 2:11 PM
After PlusNet messed up my order and forgot to send me a router I reconfigured my TalkTalk router to connect to PlusNet. This all worked well and about 55Mbps was received.
Last night I changed to the new PlusNet router and I am now getting 24Mbps and 2Mbs upload. I cant use the BT speed checker as I get flash errors. SO I have attached a result from speedtest.net. I have tried different servers and rerun a number of times and the results are almost the same every time.
Why is this happening???
02-09-2017 3:51 PM
Hello there.
Sorry to hear you're having speed issues. Our tests are detecting a potential issue.
Can you raise a fault to us at http://faults.plus.net making sure your router is plugged into the test socket?
Anoush
02-09-2017 10:30 PM
Thanks Gandalf
Speed has returned to 61Mbps and 12Mbps upload.
02-09-2017 11:48 PM
