Fibre - Lags
- Fibre - Lags
Fibre - Lags
18-06-2018 8:45 PM
I have posted before but i didnt recieve any help and advisor said that my connection is good but it is clearly not.
Every 5-10 minutes i have a huge freeze lag on every device that means if you for example play shooter, everything is stopped on my screen (and i wil die). This lag last like 5 seconds and then suddenly go back to normal. It happens on every game or any online service
I did a factory reset to plusnet router = no diffrence.
And today i cant connect to Battlefield 1 servers at all with an error "Connection to EA Online Timed Out. Your network bandwidth and/or network latency may not meet the requirements for the game"
So there is a problem with my broadband. I attach a tracroute from EA servers
Re: Fibre - Lags
19-06-2018 10:36 AM - edited 19-06-2018 10:37 AM
Hi @nacktarn,
I'm sorry to hear that you're experiencing connection issues. I've tested your line today however the test isn't picking up the cause of this. For reference, the test result is as follows:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 71.9 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 415.6 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 3dB, Retransmission Low - 0.128M-20M Upstream, Retransmission Low | ||||
Time Stamp | 2018-06-06T10:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 70.1 Mbps | 72.1 Mbps | 71.5 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 805.0 Sec | 900.0 Sec | 899.7 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-06-19T09:16:54Z | 2018-06-19T09:31:54Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Are the issues that you're experiencing solely occurring on wireless connections or are they affecting wired connections too?
Re: Fibre - Lags
19-06-2018 11:20 AM
Re: Fibre - Lags
19-06-2018 11:58 AM
I don't know what equipment you are using so this may be irrelevant. But there have been reports that some kit can get confused by the hub 1 (do you have a hub 1?) broadcasting wifi on 2 frequencies. There can be problems when devices decide to switch from one to the other, and reports of even dropping the connection. It might be worth separating the two signals. @bill888 has posted how to do that at https://community.plus.net/t5/My-Router/Devices-stop-working-on-5-GHz-connection-Wifi-drops/m-p/1395....
Re: Fibre - Lags
19-06-2018 12:05 PM - edited 19-06-2018 12:06 PM
The GEA above reports a Bridge Tap detected.
Re: Fibre - Lags
19-06-2018 12:56 PM
Hi @Strat
Yeah i saw that when I got on this thread - this will affect OP's Sync speeds obviously, and i guess if he then max's out his connection it would lag so....theoretically this could well be the issue.
I would, however, like to ask OP what he has done Wireless Channel wise (as he mentioned he has tried a few) and if he is indeed using some of our hardware, because the point made by @BrightonRock is correct, there has been issues which have been identified and then rectified with the Hub One's SSIDs.
@nacktarn - could you let us know the answers to these questions?
Thanks all
Re: Fibre - Lags
19-06-2018 10:39 PM
I've tried to set channels which internet recommends as most default but problem was still occurring then i set it back to "smart" which theoretically should look for some best channel possible in my area. None of this helped.
Regarding Bridge Tap, i didn't know about this phrase to be honest so i googled it and Hub One is in the same place where engineer left it 3 years ago and i haven't touched anything since then around the device but the problems with lagging is happening for about 1-2 months.
Thanks in advance
Re: Fibre - Lags
20-06-2018 10:22 AM
Hi @nacktarn
So - "theoretically" the Auto Smart function should scan the area and select the best channel for you router that's correct, however, personally I have had much better experiences (both with my router and from helping customers) when manually selecting a channel.
First of all I would suggest splitting and renaming your 2.4 & 5Ghz SSID's:
- Log into the Hub One by pointing a web browser to 192.168.1.254
Go to 'Advanced Settings' -> 'Wireless'.
- Click on 5 GHz wireless tab
Change the 'Sync with 2.4 GHz' to 'No'.
Assign your new wireless SSID name. eg. ConnectionName-5GHz
- Click on 2.4 GHz wireless tab
Assign your new wireless SSID name. eg. ConnectionName-2.4GHz
I would then personally change the 2.4 GHZ frequency to broadcast on either Channel 1, 6 or 11 and the 5Ghz to any channel apart from "Auto". I would then leave this configuration for about 24 hours to see if these changes have taken affect and improved your Wireless service.
I would also certainly also advise on connecting devices via a LAN cable if at all possible as this is always going to give you a much MUCH better service as unfortunately, due to the way WiFi works, there are a lot of environmental factors which can affect the wireless signal and we are never able to guarantee this.
Let us know how you get on
