Fibre Install Completed
Grezzer36
Had fibre instal completed this morn. Went ok according to engineer, should get close to max 38mb as so close to cabinet. Be great as prev 2mb due to very long line. I know I'm being a bit too eager but any chance someone at PNet can give profile nudge to up to fibre rate. Be great if you could.
Smiley
Fixes: 167
Re: Fibre Install Completed
Taking a look now.
 Chris Parr
 Plusnet Staff
Fixes: 167
That should be sorted now, I've added the discounts agreed to your account and changed your service over to fibre. You may need to log in to the router and press disconnect/reconnect for the higher speeds to come through.
 Chris Parr
 Plusnet Staff
Grezzer36
Thanks a million Chris. Disconnected & reconnected. BT speed check now gives 37.8mb down 13.3mb upload. Mega after years of 2mb. BT profile showing as 77mb I assume this normal as I'm on 40mb service.
Thanks again for mega quick response as always on forums.
Smiley
1. Best Effort Test:  -provides background information.
Download Speed  37.83 Mbps
0 Mbps 77.11 Mbps Max Achievable Speed
Download speed achieved during the test was - 37.83 Mbps
For your connection, the acceptable range of speeds is  60 Mbps-77.11 Mbps .
Additional Information:
IP Profile for your line is - 77.11 Mbps
2. Upstream Test:  -provides background information.
Upload Speed  13.35 Mbps
0 Mbps 20 Mbps Max Achievable Speed
Upload speed achieved during the test was - 13.35Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
jim:green post tidied up mod:end
Terranova667
Yeah that's pretty much right Plusnet cap the speed at their end for the 40Mb product
Grezzer36
Thanks Terranova667 that's what I assumed. So far things fine & dandy. After 9yrs of 2mb today was much anticipated & hasn't disappointed.
Smiley
Fixes: 236
Glad to see that's done the trick for you.
If you have any further issues please let us know.
 Matthew Wheeler
