Fibre Install Completed
- Re: Fibre Install Completed
11-12-2014 12:22 PM
Had fibre instal completed this morn. Went ok according to engineer, should get close to max 38mb as so close to cabinet. Be great as prev 2mb due to very long line. I know I'm being a bit too eager but any chance someone at PNet can give profile nudge to up to fibre rate. Be great if you could.
Message 1 of 7
(1,054 Views)
6 REPLIES 6
11-12-2014 1:23 PM
Taking a look now.
Message 2 of 7
(538 Views)
11-12-2014 1:34 PM
That should be sorted now, I've added the discounts agreed to your account and changed your service over to fibre. You may need to log in to the router and press disconnect/reconnect for the higher speeds to come through.
Message 3 of 7
(538 Views)
11-12-2014 1:57 PM
Thanks a million Chris. Disconnected & reconnected. BT speed check now gives 37.8mb down 13.3mb upload. Mega after years of 2mb. BT profile showing as 77mb I assume this normal as I'm on 40mb service.
Thanks again for mega quick response as always on forums.
1. Best Effort Test: -provides background information.
Download Speed 37.83 Mbps
0 Mbps 77.11 Mbps Max Achievable Speed
Download speed achieved during the test was - 37.83 Mbps
For your connection, the acceptable range of speeds is 60 Mbps-77.11 Mbps .
Additional Information:
IP Profile for your line is - 77.11 Mbps
Upload Speed 13.35 Mbps
0 Mbps 20 Mbps Max Achievable Speed
Upload speed achieved during the test was - 13.35Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
jim:green post tidied up mod:end
Message 4 of 7
(538 Views)
11-12-2014 10:42 PM
Yeah that's pretty much right Plusnet cap the speed at their end for the 40Mb product
Message 5 of 7
(538 Views)
12-12-2014 12:15 AM
Thanks Terranova667 that's what I assumed. So far things fine & dandy. After 9yrs of 2mb today was much anticipated & hasn't disappointed.
Message 6 of 7
(538 Views)
12-12-2014 9:36 AM
Message 7 of 7
(538 Views)
