Fibre Hub Issues
Fibre Hub Issues
Morning all,
I have a PlusNet Fibre Hub (the white thing with the lights at the bottom). I'm having a load of trouble with it. Having to hard reset it at least once a week because it keeps failing.
An example being I have some ports forwarded to my home file server for PLEX and other applications. I set that up last Monday, in the mean time I bought a Raspberry PI. So I log in to set up some more ports, click on the port forwarding tab, and it restarts. Try again and it does the same thing. So left with no option but to hard reset and then log all the ports in again. It's just pants, I mean it cuts off all the time, I have this issue with it, it's fairly slow at the best of times, despite showing 40mbps in the connection status, any advice or help would be great. Has anyone else had any issues like this?
Cheers
