Fibre Extra
Fibre Extra
Hi
I've just upgraded from Fibre to Fibre Extra, and had confirmation that I'm up and running. I appear to be syncing exactly the same as before upgrading. The data rate ( 9997 / 39950) is exactly the same as before, leading me to think that I'm possibly still on the 40/10 profile. More concerning are the Maximum Data Rate and Attenuation figures, which suggest I may not get much more than I was previously, anyway. I'm hoping I haven't made a mistake in upgrading. Any comments would be welcome.
Dave
3 REPLIES 3
Fixes: 43
Re: Fibre Extra
Hi @CorbyDave, thank you for getting in touch.
I can confirm that your modify order to 80/20 will complete anytime on 26/03/2020
Thank you for your patience.
 Faris
Re: Fibre Extra
Thank you.
All completed fine now. Just wish the Openreach cabinet was a bit closer!
Dave
Fixes: 43
Re: Fibre Extra
Glad to hear it has been sorted @CorbyDave,
Let us know if you have any further queries please.
 Faris
